Our Casa 90 has been assembled and is now wrapped in blankets & chicken wire awaiting stucco.
We're going for an igloo shape and I'm designing the transition from the oven vent to the chimney.
I was wondering whether I could use the FB board to surround the vent attachment and the bottom of the chimney to "support" the wire lathe and then stucco? (like how you can use foam to support shapes when you make concrete sculptures.) This would be instead of using the blanket and trying to make stucco wire completely create the shape. Can you cover the FB Board directly with stucco?
Also, can the insulation blanket touch the DuraTech chimney?
One last question, do I need a refractory mortar for the outside brick archway?
Thanks for the help.
