HI All
Has anyone tried Brisbane's woodfired oven kits?. The kit is from Total refractory management.
The kit looks good, is fairly priced ( I think) at $1300 AU and is made from a kit of pre-made refractory concreate parts.
It comes with the dome, base( cooking surface) flue, door, thermometer, insulation mat, 2 tubes refractory mortar, insulation for base etc. You just need to add the cement-sandgrout to cover the dome in.The size is 1600mm long, 1200 wide and 800mm high so is big enough for us.
Looks a lot quicker and simpler then my current thoughts of building the brick oven . ( i know the brick oven is better and gives you warms fuzzies for building it but I want good pizza before I get old enought to start worring about wherther I should be eating it.
Has anyone got any thoughts on it?
Rob
Rob
