qiardano oven on cart
  • #31
    Re: qiardano oven on cart
    thanks, i hope it all comes together soon. the weather has really slowed the finish work down. i found a nice granite shelf for the front in black. i think that will be a nice contrast to the cover
    • #32
      james how warm must it be to mortar the floor to the insulation? i am only able to work outside.
      • #33
        The manufacturer gives us a tight working temperature range, and your weather is a lot colder than what they specify.
        Does anyone have hands-on experience using a real refractory mortar in colder temperatures?
        • #34
          picked up my oven parts tonight, did a test fit ,everything seem spot on. enclosed is a pic
          • #35
            Originally posted by thezaman View Post
            received my cart and cover, i have three inches on all sides and four on the top enclosed are pics
            is that a one piece refractory cast dome ?
            • #36
              the cover is metal and weighs 91 pounds so when the whole thing is finished the oven will be under 400 pounds.
              • #37
                starting to break in the oven, it was a cold dreary day in ohio. better pictures when we got some sun.
                • #38
                  Congrats,,, Enjoy your oven..
                  Cheers and many happy pizza's
                  Mark
                  • #39
                    finally used my oven tonight, it takes longer than the primevera to get to temperature, but it holds it much better. i was shooting for 800 deg floor , which seems to give good balance top and bottom. the oven cooked nicely ,not a big difference over the primevera 70, but the primevera needed a break in period before i got good results at higher temps.enclosed are pics
                    • #40
                      Very nice Zaman,
                      Give her a little time to really dry out, and you will be looking very good. I think you will see even faster heat up and better heat retention (and better high heat pizza baking). Go for the char!
                      • #41
                        yes, after it is seasoned I'm sure it will get better, but i was very happy with the first bake!!.
