Re: qiardano oven on cart
Hey thezaman,
The small bag is an additive that makes the mortar easier to work with (more sticky and better adhesion while it dries). We have started pre-mixing the additive to keep it simple, but clearly your mortar was not mixed. Just thoroughly mix the two together while they are dry.
I have been thinking about the floor for your oven, and I am leaning toward your mortaring the floor in place because the oven will be moved. It really is 6 of one and half a dozen of the other (both methods are perfectly valid), but you have a little less change of the floor moving if you mortar it down.
You should have enough mortar to do the floor, the chimney and to seal the dome to the FB board at the bottom.
Let us know how it goes.
Hey thezaman,
