Single Pizza, Test Oven, Propane Powered.
  • Jet_deck
    • Jun 2010
    • 12
    #31
    Re: Single Pizza, Test Oven, Propane Powered.
    Uploaded with ImageShack.us
    I built this test oven on my 2 burner gas cooking cart from Academy.(Item#: 14006555,Style#: OGDBC-01,SKU: 0267-40037-0001) The burner setup is exactly like it comes, except I removed the screw in venturi from the right hand side burner and pointed it up into the gas range burner. The cooking cart already had seperate L and R controls. I hope this helps, my intention wasn't to confuse anyone, just to get directly to testing and cooking. Anybody have ideas for a simple adjustable dough sheeter?
    • JoeyVelderrain
      • 306
      #32
      Pretty cool, smple and it does the job, can't ask for more than that.
      From what I've read it isn't a good idea to run the dough through a sheeter something similar due to the bubbles being pressed out of the dough and it would be counter productive, that being said it is a excellent idea. I think going with some kind of rolling pins (here are some non stick type)
      Teflon Non-Stick Rolling pin. Large Collection of Rolling Pins in Sydney - Food Utensils
      and adapting some type of sprocket or pulley to one end with a rotisserie motor should do the trick.
      • Jet_deck
        • Jun 2010
        • 12
        #33
        • JoeyVelderrain
          • 306
          #34
          I finally had a chance to start working on my test oven, here are a couple of pictures of what I have so far.
          aluminum sheet metal enclosure and kiln shelving.
          (I kind of slapped it together so it will not look store bought but hopefully will function as expected)
          Now I will install the insulation on the top and fabricate the bottom shelf for the rotisserie motor.
          • JoeyVelderrain
            • 306
            #35
            Fabricated a removable top and installed the insulation.
            first layer of insulating blanket.
            second layer..
            and a removable top!
            • Jet_deck
              • Jun 2010
              • 12
              #36
              Sweet! Will the burner be anywhere close to the aluminum where it is unlined with the shelving?
              Are you bending the aluminum by hand or do you have a break?
              Nice and shiny, gonna have to get some bling too.
              • JoeyVelderrain
                • 306
                #37
                I'm thinking of having a burner directly under the turntable and two more facing the top stone, I'm still in the planning stages of burner set up.
                • JoeyVelderrain
                  • 306
                  #38
                  I attached the turntable support shelf but I am out of time, have to return to work on the BP incident. I shall return in about a month or so...
                  • JoeyVelderrain
                    • 306
                    #39
                    ok, fast forward a couple of months and I have tested the oven to see how the home made burners burned and the turn table operated.
                    video 1
                    Verdict:
                    video 2
                    Turn table
                    The turntable worked great and did not over heat, I did notice that the shelf that holds the rotisserie motor gets hot and tends to sag, I will need to re enforce it somehow.
                    Home made burners
                    The home made jets are burning with entirely too much soot, it is obviously an air to propane mixture problem. I am looking at a commercially available replacement for these. A problem will be that there is a size limitation inside the oven.
                    • shuboyje
                      • May 2009
                      • 406
                      #40
                      Maybe these would work.
                      A simple homemade propane burner
                      • Lburou
                        • Dec 2010
                        • 1165
                        #41
                        You could test using the propane burner from a turkey cooker -a Southerner will know what that is
                        Lee B.
                        DFW area, Texas, USA
                        • JoeyVelderrain
                          • 306
                          #42
                          I have started working on test oven 2.0 since I melted the last one. This one will be made out of steel and I am sacrificing my dolly so it will be chest high and be portable instead of tabletop. I will post build pictures tomorrow.
