First time 41" clay/homebrew oven.
  • sandybits
    • Jul 2013
    • 31
    #46
    Re: First time 41" clay/homebrew oven.
    Thanks guys. I did end up tipping the beads out. I saw some steam coming out of the insulation layer so moved them to another spot.
    The pile of beads was too small though. I think I was being to "cheap" and didn't want to use of the $10 bag of beads in one go.
    I put the door on the oven but the areas away from the beads only got a few degrees above ambient.
    I don't so few beads did a lot. However the little bit of steam coming out the back suggest that it moved some water, I guess.
    • sandybits
      • Jul 2013
      • 31
      #47
      I went against the grain and built a fire that has kindling criss crossed over a couple of larger logs (the against the grain bit is that I have always been a teepee guy, very fine tinder into kindling, into twigs, sticks, branches, etc - all manual) with a firelighter underneath.
      I've got to admit I think my fire lighting techniques have changed from this experiment. It was a little too easy to do this way - although I have only tried it twice. But every other small fire I tried t get going in this oven didn't work.
      I also took some picture and some temperature measurements. I post them here for no other reason then someone yelling, "crikey, that's not right!"
      The first photos show the finished oven'
      The next 2 show the little fire /small temps' and
      the last 2 show damage to the undercover area. Whoops.
      • sandybits
        • Jul 2013
        • 31
        #48
        Here re the temps. I hope they make sense.
        • brickie in oz
          • 3445
          #49
          Those last two pics of the effects of the heat from the flue made me laugh.....
          • sandybits
            • Jul 2013
            • 31
            #50
            Me too. I expected it but thought I'd give it a run and see what happened. Now I know.
            • brickie in oz
              • 3445
              #51
              At least you know where to cut now....
              • sandybits
                • Jul 2013
                • 31
                #52
                I might not have to cut. I'll just fire the oven up really hot and burn straight through
