Veraci-style clay oven materials advice
  • daponte
    • Jun 2013
    • 4
    Hi all -
    (Trying one last time to get this post through by removing urls...)
    So I'm determined to build a mobile horno oven in the style of Veraci Pizza's. It seems I can't add urls as first-time poster, so you'll need to google to see the style I'm talking about.
    They don't share specifics, but their site says the ovens are a "refractory clay mixture" and I've heard through the grapevine that they are a mix of clay and cement.
    I'm imagining that the process is similar to a Kiko Denzer-style build: a sand mold, covered over in a few layers, let to dry, and cured.
    But I've read elsewhere that the more clay you have in a mix, the more cracking you're going to have. That doesn't seem to be the case with Veraci's, however, and I'd love more experienced builders' ideas on how to achieve this.
    Once I get a reasonable idea what to mix with my clay (nice gray/green clay I'm harvesting), I'm going to do some testing out of different mix ratios.
    Thanks in advance for your help and advice!
    • 2848
    Re: Veraci-style clay oven materials advice
    G'day
    Why don't you investigate using 50/50 high temp ciment and grog ethier cruched firebrick or crusher dust (powdered basalt). It's been done before no clay no cracks
