Hello,
I decided on the gym ball vermiculite mix approach to the oven. The entire thing is cast and in situ on the firebricks. It was built as a single cast over an 80cm ball so is 80cm in diameter. The dome was cast with 1:5 cement fondu and vermiculite and set quite hard after about a week. We then moved the heavy lump onto its platform and vermicreted it in using the same mix. After another couple of days I added another less compact layer of vermiculite to portland as an insulating layer, so that the first layer is about 2-3 inches thick, followed by an insulation layer of around 2 inches again but less compact.
I let that rest for a couple of days then did a very small fire just using scrunched up paper to help push the moisture outwards as suggested. This created quite a low heat and I was planning on doing the same once or twice a day for a while to gradually get rid of the moisture before rendering. The burn produced a lot of smoke so I could make sure the chimney worked ok (which it did). However I noticed some very fine whisps of smoke escaping from some places in the dome itself. I took a torch to the inside of the oven and there are some gaps about a cm or so in places that do seem to correlate to where the smoke leakage is occurring.
My choices are I either adding a ceramic blanket then chicken wire, followed by a render to add insulation and keep the heat directed back into the oven. I have about a fifth of a bag of vermiculite left so I could add some more compressed vermiculite cement (but I've run out of ciment fondu so it would be an ordinary cement/vermiculite mix), use a small tub of fire cement and plug the holes inside or any or all of these maybe?
What are the thoughts of anyone who has made a vermiculite/cement dome using the gym ball method. I appreciate that others have used firebricks etc and may not like the vermicrete approach, but the cost of the firebrick floor was more than enough so it wasn't an option to go for a full dome as well.
