So next stage.... Remove the formwork from the entrance and let the oven air dry under the temporary gazebo for... 2 weeks? (can someone advise).
I also need to make a door but i've run out of vermiculite so considering buying some boards and making a fancy door with vermicrete boards, decking boards, fireproof rope / adhesive and some handles. I don't fully know yet.
I also need to render it. I need to make it weather proof as it is not having a cover. I think i will make a temporary cover for the winter periods out of a thick tarp specially sewed up, but essentially this will be out in the open (it's quite a sheltered garden).
Question: can i tile this? I want to do a fancy mosiac pattern. If i do, do i still need to put a stucco / render scratch coat on it first? If so how thick?
Thanks.
I probably won;t be setting any fires in this now until at least the beginning of September, then i'll brave the 7 fires over 7 days. need to consider the final finish though. Any advice is appreciated.
Cheers all. PS. some of you oven builds that i've been following over the passed few months look really good!! Thanks for the inspiration
Thanks.
