Hi there,finally able to kick off my 32" build after initial research/planning last year. An overview/plan for each of the categories below, but I will add/link a dedicated question list /progress post as I get to each milestone.
Big shout out to Mullster , sergetania , Nick J C for their great build logs last year, and david s for the continued contribution; a quick read through those threads definitely fill in many gaps for the novice/inexperienced builder.
Design Plans:
Overview:
Foundation:
Stand/Base/Hearth: (post #3) - In Progress
Insulation:
Firebrick:
Dome/gallery mold:
Dome/gallery:
Breather valve/pipe:
Cast Facade:
Additional post to follow with details/questions of each phase of build.
Design Plans:
Overview:
The oven will be 32", homebrew cast on a metal stand.
| Parameter | Value |
| Dome ID | 32" |
| Dome Thickness | 2" |
| Blanket Thickness | 2" (maybe 2x 1.5" layers) |
| VCrete Thickness | 1.5" |
| Render | 0.75" |
| CalSil Thickness | 4" |
Foundation:
The oven will sit on top of an old hot tub pad that is embedded into the patio.
Metal stand: I bought and retrofit a 60"x60" metal table/stand off Craigslist constructed from 2" steel tube.
Platform: 1.5" Exterior plywood + thin set + 1/4" cement board, 1.5" plywood edges sealed with Titebond 3 waterproof glue
Waterproofing membrane (undecided): Potentially seal cement board with Redguard membrane to prevent moisture absorption into plywood, worth the $50?
Under-Hearth Concrete Pad (undecided): At the moment, I plan to pour a 2" pad that will go under the insulation in the shape of the oven (out to the blanket layer). My thought is this gets it plenty off the top of base and limits any water getting in the CalSil, it also raises the height of the oven floor.
Ceramic Tiles: 1/4" ceramic tile (6"x6") that will go under the insulation.
Weep holes: 4-5 0.5" holes drilled through plywood, cement board, concrete pad
Insulation:
Thermo-1200 in 2" (9 pcs for a total of 27 sq ft) for ~$130
Use 4" (2 layers) under fire brick
Firebrick:
Standard firebrick from brick yard (regular/medium duty fireplace brick?)
Dome/gallery mold:
Dome mold: Stack 12"x12"x1" foam sheets as filler, then top off with sand for shaping
Gallery mold: Design gallery in CAD, create 1" and 0.5" cross sectional slices to be laser cut out of EPS foam
Dome/gallery:
Homebrew:
Clay: Hawthorne-35 - 100 lbs
Cement, Sand, Lime: TBD
Melt extract fibers/SS needles:
5 pounds (slightly under 2% by vol)
Polypropylene burnout fibers:
Nycon Procon M 19mm/ 0.75" fibers (38 microns / melt point 320 deg F)
Purchased 2 pound sample for $10+shipping from Nycon
Chimney: Purchased 2 pound sample for $10+shipping from Nycon
Already purchased a 6" Supervent anchor plate. I'll trim/cut some of the stock plate down so it can fit on top of the cast gallery where I'll embed in some threaded rod/bolt to attach to.
Will likely do similar pipe+cap seen in other recent build
Cast Facade:
Cast tile/decorative glass front facade similar to other recent builds
