another steel dome oven
  • metalmaster
    • Mar 2008
    • 62
    I was going to build a conventional oven, but since this large ball found it's
    way onto the property things have changed.
    the plan is to split the ball in half and construct a steel inner oven
    then weld the ball back together and fill with insulation.
    that's the plan anyway
  • ERASMO
    • Oct 2008
    • 85
    Re: another steel dome oven
    Great idea. Please keep us posted.
      I bet that loop on top would come in handy moving the thing around. In theory you could make two domes from the same sphere.
      • metalmaster
        • Mar 2008
        • 62
        we where going to make two ovens out of this,but by using the ball we eliminate
        pouring a slab and building a concrete block base.
        the plan is to weld the ball on top of a 8" diameter pipe set in concrete
        • metalmaster
          • Mar 2008
          • 62
          this is the basic idea for the oven so far.
          we are thinking about making the ball rotate on the base.
            That is just TOO cool.I'm thinking a slightly larger diameter support would leave it looking less lollypop like, but I really like the idea. Maybe one of the truck rims you make your entry out of, split, and stretched with a length of pipe.
            • metalmaster
              • Mar 2008
              • 62
              well we cut the ball in two today.
              the inside is a little sad looking, but a wire brush will clean it right up
              • Wiley
                • Mar 2008
                • 804
                It doesn't look that bad for a mooring ball, did it come from the Sacramento River?
                Bests,
                Wiley
                • metalmaster
                  • Mar 2008
                  • 62
                  I think it came out of someones yard that lived along the river.
                  the guy we got it from said it floated into his yard during the floods of 1986.
                  these are surplus bouys that where converted to well tanks, they are all over
                  the place around here.
                  • ThisOldGarageNJ
                    • 1436
                    sounds like a great idea.... Love the smoker you have in the background, Did you build that too ?
                    • metalmaster
                      • Mar 2008
                      • 62
                      we are building the pizza "ball" at my mother in laws property (the compound).
                      the smoker was built by my brother in law, we have been cooking pizza in it.
                      the first picture is the ball mocked up to test the location, the last picture is
                      what we had for dinner last night
                      • ThisOldGarageNJ
                        • 1436
                        How are you going to fill the bottom of the ball ?? vermicrete ?? then lay fire brick on top ??
                        • metalmaster
                          • Mar 2008
                          • 62
                          we are going to weld supports in the bottom of the ball and pour a 6" layer of perlcrete
                          before we lay the firebrick.
                          • ThisOldGarageNJ
                            • 1436
                            sounds like a cool project,, will you flip over the top to insulate it ?? and what plan do you have for a landing,, This is a very intriguing build,, keep the pics coming im sure we are all anxious to see it progressing
                            • metalmaster
                              • Mar 2008
                              • 62
                              if you look at the cad drawing you can see that there is about a 9" distance
                              from the inner dome to the outer ball.
                              after we build the inner dome we will weld the outer ball back together, then cut
                              about a 14" dia hole in the top to pour loose perlite in.
                              when it is all done we are thinking about painting it like an 8 ball.
                              Last edited by metalmaster; 09-10-2009, 10:37 PM. Reason: double checked drawing for dimension
