Bend, Oregon USA 29" interior Floor
  • Tscarborough
    • Oct 2009
    • 3341
    #46
    Re: Bend, Oregon USA 29" interior Floor
    Just some cracking where I mentioned.
    • 100million
      • Feb 2010
      • 141
      #47
      Well here we go another hard day building WFO
      I used my WANT TO BE Certified installer to work the details of the edges, transitions, and joints when I use the acrylic finishes designed for EIFS systems, which are also used by non-certified installers.
      I hope it works
      The Smooth finish was very hard to make smooth with a round dome.....Or was it That i had a non certifed trowel? So I mad Ruff Finish.
      Tscarborough it is all in love and fun....thanks for all the info...Like the COLOR?
      Chris
      • 100million
        • Feb 2010
        • 141
        #48
        Well
        This is my first Firing with the STO Stucco on it
        I am still in the Testing Stages
        And Look at the pictures to see the heat results
        Floor is 729
        Inside of the Ceiling is 968
        Outside of the dome is 98....7
        The Chimney on the inside is 436
        All looks good sofar
        Chris
        • Tscarborough
          • Oct 2009
          • 3341
          #49
          The color is nice. Did you make that gas rig?
          • 100million
            • Feb 2010
            • 141
            #50
            I have made everthing so far
            And if you want to talk about the Gas Rig, it needs to be done in PM...Becasue of WFO use WOOD
            • Tscarborough
              • Oct 2009
              • 3341
              #51
              I would like to build one to do warm ups AFTER the fire is out.
              • 100million
                • Feb 2010
                • 141
                #52
                Well I did some calculations on how long it took to build the oven
                The master brick layer and the master designer took 65 hours total to get it to this point
                • Dino_Pizza
                  • Feb 2008
                  • 1036
                  #53
                  Chris, did you really keep track of your building time? Well, besides now being master builder and designer, I'm nominating you master auditor as well .
                  Have all your curings been with the gas? Now that you're at almost 1000 deg on the dome, when are you going do the wood firing and 1st pizzas?
                  I think your oven will draw smoke really well, can't wait to see it,
                  Cheers, Dino
                  My Oven Costs Spreadsheet
                  My Oven Thread
                  • 100million
                    • Feb 2010
                    • 141
                    #54
                    Cheers, Dino
                    The time I keep track of was ONLY standing over and working on the oven.
                    Going to the store and get more bricks or glue stucco etc does not count.
                    My Friend Sergio BRAVO is the Master Brick layer and he took 39 hours. I was the rest of the time.
                    I was the master designer, brick cutter, grunt, hod carrier and mortar mixer and the ROOKIE as SERGIO would say.....but with the RESEARCH on FB forum we took all the Ideas and came up with my oven.
                    About the Wood and Pizza it is coming soon
                    I just have a few more trick up my sleeve...... I will get some more pictures soon
                    BUT Pizza will be soon
                    Thanks Dino....................... Oh Master Builder and WFO SLAVE
                    • 100million
                      • Feb 2010
                      • 141
                      #55
                      At last moving the oven.....It is nice that I have a FORK LIFT to lift this 1540 lb oven
                      • 100million
                        • Feb 2010
                        • 141
                        #56
                        Just thought I would let you all know ....I havent died and have not fallen off the face of the earth......I have been working on the pizza oven and I think I can show you the progress now
                        • Jed
                          • Apr 2008
                          • 428
                          #57
                          Wow Chris,
                          The oven looks great!.
                          Looking forward to supporting your business this summer.
                          JED
                          • fxpose
                            • Jul 2009
                            • 942
                            #58
                            That is one, solid looking piece of equipment! Nice job on the rig!
                            George
                            My 34" WFO build
                            • Dino_Pizza
                              • Feb 2008
                              • 1036
                              #59
                              Chris, really like the steel side table and front ledge. Did you weld all that stuff? You guys are a talented bunch. If your pizza's come out anywhere near as good as your construction, it'll be impressive.
                              Cheers, Dino
                              My Oven Thread
                              • 100million
                                • Feb 2010
                                • 141
                                #60
                                Cheers, Dino
                                I am the master builder but not the master brick layer (setter) that is "Sergio Bravo" and not related to "Forno Bravo" and I am only a rookie Brick Oven Trailer Builder.
                                Chris
