to light the dome is it possiable
  • olddude
    • Jul 2009
    • 61
    just got the go a head to start the dome
    thought i might try to light the dome
    thinking if i put a glass title / lens at the top
    with a sleeve then a lamp and socket at the top
    so i can change the lamp
    if it don't work i can go back and take it out and close up the dome
  • eprante
    • May 2009
    • 282
    Re: to light the dome is it possiable
    You might want to consider putting it in the side. The dome is the hottest part of the oven. Check out post # 43 on Re: 81 inch First Build under the commercial oven section.
    Seems like that may work.
    E
    • Neil2
      • Oct 2006
      • 1374
      Or you can get one of these:
      • olddude
        • Jul 2009
        • 61
        okay god point side it is then
        know to find the glass lens
        title
        • nissanneill
          • Apr 2007
          • 1886
          olddude
          why not do as I did, mounted a couple of domestic down lights in my chimney void (as it is quite large) but I also mounted some plastic LED lights on Hendos oven outside the outer arch where the light is beamed into and across the oven opening. They work a treat and I wouldn't consider anything else.
          I have duplicated the pics from my Pompeii build to show the difference with the lights.
          They need a wipe with a moist cloth once a year, usually when cold.
          Cheers.
          Neill’s Pompeiii #1
          Neill’s kitchen underway
