Stefanno Ferara Napoli Oven Constuction
  • dhs
    • Oct 2008
    • 45
    Slice.Seriouseasts.com blog has a great slide show of the construction of Donna Arapai's new oven
    Oven Slide Show
  • Lburou
    • Dec 2010
    • 1165
    Oven Construction by a recognized craftsman...
    This slide show has changed my focus from worrying about details to 'getting it done'. Thank you, thank you!
    This craftsman literally enjoys rock star status in Italy....And look at his brickwork. My conclusion is that I want an oven to bake in, not brag about
    Some of the builders here are capable of building satellites, they are so clean and precise. Well, a sturdy oven per the plans I will build, but I'm not going to be that clean or precise....and I refuse to feel guilty about it!
    Thanks again for the link!
    Lee B.
    DFW area, Texas, USA
      Re: Stefanno Ferara Napoli Oven Constuction
      Yeah, this was discussed here last spring when it showed up: it bears repeating. Most interesting is the filling of the gaps of the bricks with refractory castable slurry. That sure saves a lot of problems.
      • sjdritz
        • Nov 2009
        • 67
        When you look at the build photo's, Its amazing how close his bricks are to the edge of the mobile stand. Does he not use insulation? How does he get away with doing it like that? I am planning to build a 36 inch oven with a 60 inch metal stand.
        Scott
        • Lburou
          • Dec 2010
          • 1165
          Scott
          Mobile stand? Looks like they are building around the seriously substantial base as a permanent location....Am i missing something?
          Lee B.
          • lwood
            • Jul 2009
            • 632
            Stefanno is suppose to be the "authority" on Neapolitan ovens so I think this warrants a close look. Who knows what is under that mound of concrete. I couldn't find any pics showing any of that. He has a flue packed in there also, I would think there is insulation in there as well. The flue is a squirrel-tail going out the rear. He is recovering some heat from the flue as it goes over the dome.
            Very interesting construction method; looks to be a sand mold and he lays up the dome on the sand mold without much if any mortar. Then pours the slurry over the whole dome to fill in the spaces. This must be because of the low dome that it appears to be. Notice the buttressing around around the base, maybe 8" high then he starts the dome. Certainly the buttressing is done for the low dome configuration.
            Watched the video discussion with Stefanno on the New York Post review and he talks about a book that was written in I think 1790 (couldn't hear the exact date) on how to build an oven. He is still using those same methods...and very passionate about it.... Anyone contemplating a low dome oven should probably view this.
            Wonder how much that oven cost? Must have been very expensive. Stefanno, wife and crew all came over from Napoli and also shipped all the materials.
            • sjdritz
              • Nov 2009
              • 67
              lwood,
              Do you have a link for that video? Thanks,
              Scott
              • lwood
                • Jul 2009
                • 632
                Sorry it wasn't the NY Post, here it is => Video: Neapolitans Talk Pizza (While Ed Levine Antagonizes Them!) | Slice Pizza Blog
                • wood-fired
                  • Jul 2009
                  • 16
                  i've just taken some photos of a stefano ferrara oven here in the uk which came prefabricated. He may be a legend but the brickwork is appalling and goes counter to everything you learn about fire cement and thin joint construction! A master can get away with it but if I laid bricks like that for any of my clients I would be hauled to one side and sacked. I've got to 'copy' a Ferrara oven for a pizzeria and to be honest my pride wouldn't let me build so sloppily even though I would make a lot more money if I worked that way saving on all the brickwork cuts.
                  I think Alex Chernov is the master and I've followed his method here on my slideshow Wood-fired Ovens : Forno Bravo Casa Oven
                  but Alex isn't Italian or more importantly Neapolitan.......
                  The one I've seen works but is a gas oven and doesn't seem to have that much insulation as the dome is quite warm when fired up......I'm a bit deflated by seeing those photos you posted......maybe all the care and attention isn't worth it after all!
                  Amrit
                  • Lburou
                    • Dec 2010
                    • 1165
                    Moderation is the ticket in my view
                    Originally posted by wood-fired
                    ....snip......I'm a bit deflated by seeing those photos you posted......maybe all the care and attention isn't worth it after all!
                    Amrit
                    Your points are well taken. l think the dance on these issues is some where in the middle
                    Pride in your work is important. Let your customer define the focus, price accordingly, and go with the flow.
                    Lee B.
                    • wood-fired
                      • Jul 2009
                      • 16
                      I guess the owner didn't see how it was built if it came prefab. I should show him the slideshow and ask him if he wants it built the same, could save a lot of time on site as its away from home! I didn't use any formwork so the joints had to be tight to ensure stability. The Ferrara oven also had a refractory concrete hearth which is ok, but for the money I would want a firebrick or tile hearth.
                      • Cheesesteak
                        • Mar 2011
                        • 192
                        here's another set of pictures of Stefano on another build:
                        Stefano Ferrara Building Neapolitan Pizza Oven
                        • das
                          • Mar 2011
                          • 13
                          ^ Interesting, that thing isn't leaving without a jackhammer and sledge.
                          Anybody know what that worn, porous, almost mossy looking brick is that he seems to use for insulation. Seems the layer directly beneath the floor is just porous brick with air-gaps, explains why he use the large refractory floor tiles since he isn't working with a flat/solid sub-surface.
                          • Cheesesteak
                            • Mar 2011
                            • 192
                            It's Tuff stone - or "tufa" as it's sometimes called (at least here in the western US). Lots of buildings in italy are made of tuff stone - because you can carve it easily. Interesting . . .
                            • brickie in oz
                              • 3445
                              I hope you boys dont cut your bricks as 3 fingered Lello does here?
