Soak bricks using Heat Stop 50
  • doobie dee
    • May 2010
    • 31
    Can anyone tell me if I'm supposed to soak my firebrick as I use Heat Stop? Thank you.
  • Tscarborough
    • Oct 2009
    • 3341
    Re: Soak bricks using Heat Stop 50
    You can dip them, but should not soak them.
    • SCChris
      • Jun 2009
      • 1213
      Also make sure you clean the brick after the cutting process so your mortar has a clean surface to bond to. You'll get a feel for it quickly.
      Chris
      • charger10s
        • Apr 2009
        • 78
        So, we should not soak them? Is that true for all high heat mortar, or specific to the Heat Stop (I have Thermal Ceramics Smoothset)? For some reason, I thought I read somewhere that the bricks should be soaked, so the mortar does not dry out too quickly.
        Toby
        • Tscarborough
          • Oct 2009
          • 3341
          That is true for all masonry.
          • doobie dee
            • May 2010
            • 31
            Thanks for the help. That's where I think my last set of refractory mortar went bad. The bricks were soaked and the mortar never set.
            • charger10s
              • Apr 2009
              • 78
              I glad you asked the question! I was going to mess up big time!
              Toby
              • WoodchuckDad
                • Apr 2010
                • 209
                I am just getting started on my Oven. I have the soldiers and one course above that completed. I have found about 5 seconds in water give or take, depending on the consistency of my heatstop 50 once I have mixed it. I try for a thick peanut butter but a couple times came out with more like pudding I am being more diligent about it as I go. Don't want to mess the whole things up.
                WCD
                My slow journey to pizza.
                http://www.fornobravo.com/forum/f21/...ing-12769.html
