Hi all,
Just about to start my WFO but I need to get your thoughts first! I've got myself an old aga door, 37cm (15.5inch) wide x 32cm(12.5) high (with built in thermometer) which I plan to use on my WFO however my oven is only going to be 80cm (32 inch) in diameter therefore using the 63% rule the dome needs to be 51cm(20 inch) high.
I'm concerned that the dimensions of the door cause problems with cooking as most openings are usually 12 inch high and say 18 inches wide, they also have an arch opening however the aga doors are rectangular therefore the opening needs to be rectangular too.
Is the door going to cause more problems than it's worth and should I just forget about it altogether?
Many thanks
Rob
Many thanks
Rob
