I am interested to know while buliding the dome what holds the bricks in place at the angle that they sit?
Re: Dome
They can be cut at an angle or you can just use a big wedge of mortar. lately some have been suggesting that the solider course is not needed at all.
You can also use a form to hold the bricks in place, but this makes it more difficult to get a clean neat dome...My Oven Thread:
Re: Dome
see my thread if you want. I cut my soldiers at a 20 degree angle. Look for PizzaBob's build, it is way better. Also, go to youtube.com and search for Forno Bravo. See the first video, which shows how to build, using time lapse photos. To me, it seems like the whole dome is predicated on a well built inner arch. The dome rests upon this. I took the time to cut all my bricks using a compound cut, which was for the angle and the bevel, then because I did a crappy job on my arch, I also cut each brick from inner dome to outer, apparently known as the slope cut. But that youtube video is the best.
Good luck
Re: Dome
I did not use soldiers. I laid the first 3 courses straight up.
Re: Dome
YouTube - Pompeii Pizza Oven ConstructionOriginally posted by ThermoJax View Postsee my thread if you want. I cut my soldiers at a 20 degree angle. Look for PizzaBob's build, it is way better. Also, go to youtube.com and search for Forno Bravo. See the first video, which shows how to build, using time lapse photos. To me, it seems like the whole dome is predicated on a well built inner arch. The dome rests upon this. I took the time to cut all my bricks using a compound cut, which was for the angle and the bevel, then because I did a crappy job on my arch, I also cut each brick from inner dome to outer, apparently known as the slope cut. But that youtube video is the best.
Good luck
Is this the video?
