my pizza oven developed a crack in the vent - right above the door - do I need to worry about that? It even put a hairline crack in the flagstone on the top of the oven. I have attached a picture (I hope) so you can see the oven. what do I need to be concerned about?
Crack in Vent
Re: Crack in Vent
Can you post a close up picture of the crack?
Nice looking outside area are you have there
Bottom line for me would be to keep the oven dry inside....Does the crack compromise your dry envelope for the oven? Does the crack cause a smoke leak that bothers you?
I don't have experience with a cracked oven but have read several threads here about patching cracks, you might do a search on fornobravo for 'crack' and read up on the experience of others here
Sorry you had to wait so long for a reply.
Lee B.
DFW area, Texas, USA
I try to learn from my mistakes, and from yours when you give me a heads up. -
Re: Crack in Vent
We have been using it with no problems. The crack has not gotten any larger and it is outside of the cooking area (actually, there may be a small crack inside by the door). It really has not impacted it at all, so I think we will just leave it alone. Thanks for the reply! :-DComment
Re: Crack in Vent
The crack probably happened on a weekend during the races over by the InterstateWe have been using it with no problems. The crack has not gotten any larger and it is outside of the cooking area (actually, there may be a small crack inside by the door). It really has not impacted it at all, so I think we will just leave it alone. Thanks for the reply! :-D
Lee B.
I try to learn from my mistakes, and from yours when you give me a heads up.Comment
Re: Crack in Vent
I'm affraid if you do that you will get one gazillion hits. I don't think anything has been discussed more than cracks.
Bauchert,
I think your approach works - if it's not causing any issues, leave it alone.
Les...Check out my pictures here:
If at first you don't succeed... Skydiving isn't for you.Comment
