Has anyone?
  • Lousdepot
    • Apr 2010
    • 52
    #16
    Re: Has anyone?
    the outer color coat is separating from the first coat. I believe i followed the recommended coat thickness. i just think this is the side of the dome that doesn't get any sun. first coat never dried completely when i applied the color coat, i assume. the rest of dome that gets constant sunshine is fine.
    • Nic The Landscaper
      • Jul 2010
      • 100
      #17
      Re: Has anyone?
      What materials are you using for both base coat and finish coat?
      • Lousdepot
        • Apr 2010
        • 52
        #18
        Re: Has anyone?
        STO base that i had to mix myself and then the finish came in 5 gallon bucket ready to go.. i followed all instructions..
          • Jul 2010
          • 100
          #19
          Re: Has anyone?
          Base should have cured for several weeks prior to installing finish coat. The base needs to be 100% dry/cured before finish gets applied. A bonding/priming agent between base and finish coat would have helped but that's all hind sight. Also while an elastomeric finish coat is curing it should not be exposed to rain/moisture or freezing temps, preferably for 2 weeks. I would wait for a couple days of warm (50 degree plus) dry weather days and patch it. Use a paint brush to feather the patch into the existing finish and you'll barely notice it.
          • DaveW
            • Oct 2009
            • 200
            #20
            Re: Has anyone?
            I like this one too......
            http://www.fornobravo.com/forum/21/f...oo-5702-7.html
            Dave
            Album: http://picasaweb.google.com/fornososo/Pizza#
