I am so bad, I didn't even ask the question correctly! LOL
John
Just kidding, I will do my best from the stand point of going through the build and letting you know what I did and if it worked out or not.
Unless you have butressed it and not shown us I would hesitate to place so much weight on it. Perhaps a few firebrick columns against the sides of the arch, or some angle brackets to prevent blowout. I would hate to see all of that work collapse...
It did cross my mind that was a little too much weight for the arches. I was thinking if I had to do something like that, then the stud walls I am planning on using will give lateral support to the front arch and I will bring that back towards the rear arch and do the same. Then over the vent tie them together, I may possibly use unistrut for the "bridge" I have gone through many threads without seeing many brick chimney supports. Dmun and another which escapes me at the moment are two that I have seen.
Please someone let me know if this is correct or I am better off stacking the brick on top of the firebrick for strength!
