Re: I'm getting closer to my Dome!
Thanks Mike, I'll do just that! I do start from the entry side and work around, I was paying more attention (or no attention to the vertical joints
) to the curve and angle cuts and the upside down vee bevel than to the joints lining up!
btw, should I start clockwise or counter clockwise? I am located north of the equator if that means anything!
lol
John
) to the curve and angle cuts and the upside down vee bevel than to the joints lining up! btw, should I start clockwise or counter clockwise? I am located north of the equator if that means anything!
lolThanks
John
Then is was arch day today, and boy was it a little frustrating to say the least. I needed a primer on cutting brick tapers and back to geometry for finding an arc with a 20" chord and 4.5" height. Ok so I did get that all done and started cutting bricks with the proper angles and all. I should have cut the bricks a little smaller as the saw tended to push off the brick at the end of the angle. I dry stacked the arch just to see how badly I did and if I needed to start over again. I'll look it over in a day or so and then decide. It has been nothing but gloom and rain on and off here, its down right miserable. But I think it is probably great for the mortar to cure properly! Here are some update pics!
