Re: I'm getting closer to my Dome!
I had all intentions on doing a heat study this weekend, but a major thunder storm interrupted our pizza party and subsequently heating the oven to max. temps. The pizza party was still almost perfect tho, pizza dough was the best I ever made, thankks to Rossco's thread. The lightning came just as I pulled the last pie from the oven (my dinner) then the down pour. Of well I'll go out now an read the temp of the dome and hearth and edit this post with results.
I did get cement board on the sides but no roof yet, so it was a major scramble to get the trap up over the steel studs. I also filled the enclosure with coarse vermiculite, so I needed to hurry so that didn't get all wet! Argh! If it ever stops raining long enough I can finally have a roof! Sheesh!
Hearth Temp @ 7:30am 538 F
Dome Temp @7:30 am 564 F
Hearth Temp @ 7:30 pm after bread bake & Dinner 422 F
Dome Temp @ 7:30 pm ---------------------------------461 F
NEXT DAY
Hearth Temp @ 7:40 am 361 F
Dome Temp @ 7:40 am 368 F
The above was the last cool down temp. Wife wanted to cook some chicken dish that required a hotter oven. Threw a couple of small logs in and started a fire. Within 20 minutes the oven was back up to 510 F and I had to break up the fire so it didn't get too hot.
Chicken came out great!
Originally posted by SableSprings View PostYou noted that you were going to do some temperature tracking on the oven with your fabulous heat retention. I've been doing some temperature tracking on my oven the last couple months and it has been very helpful in prepping for meals and bread bakes. I have to admit that pizza has not been a primary use of my oven...it's bread. Normally a neighbor comes down on Friday and the two of us bake 15-25 loaves in the afternoon. I started taking readings with my IR temp gun and noting them down on the hour. The next day I graph the results in Excel to get a feel for the oven heat signatures. I've attached the last oven bake graph where I put 24 baguettes through after the daily (morning) firing.
As you have noticed, I also sometimes get some black cinders on the landing (from the chimney). I just blow them back into the oven when I fire it up or brush them into the ash slot...no worries.
I will find out how good the heat retention really is with a pizza bake Friday night, some bread Saturday and a roast on Sunday. Heat retention is one thing, stored heat to bake 15-20 loaves is certainly another. Wow what thermal mass! My bread baking will be only 6 loaves this time!
Originally posted by david s View PostI sometimes get little flakey sooty bits falling down on my oven too. I don't think there's much you can do to prevent it. I tend to burn any kind of wood I can find (best wood is free wood) Maybe overloading the chamber with fuel is the culprit, so there is unburnt fuel going up the flue. I just blow the black stuff off with my blowpipe.
Thanks for the insite
Originally posted by Laurentius View PostHi Aegis,
When I first started using my oven I burned a lot of pine and evergreen wood and my chimney was a mess. I did a long radical burn where fire was coming out of the front of my oven and that cleaned the chimney of the build up.
Originally posted by ggoose View PostCreosote is produced from condensing gases in the smoke of a cool fire, or a hot fire but the smoke cools before exiting the chimney. It then sticks to everything. One way of reducing it might be to have an outer arch door that allows a draft to feed the fire as well as holds the smoke at higher temps, allowing the gases to remain hot as they go up the chimney. Even then, you will still get build up, and will need to occasionally brush the smoke stack. Just cover the hearth bricks before you sweep the chimney.
gene
Hi Aegis,
gene
Ok I need a little help again! lol I have been working on the chimney and had several good fires and a pizza bake. Now I am having creosote/carbon fall from my flue onto my entry way hearth bricks. What's up wit dat? Did I build it wrong? How does anyone keep the carbon off or how do you clean it up without using copious amounts of water?
Thanks in Advance
Originally posted by GianniFocaccia View PostJohn - Great idea! I knew I was saving all those firebrick chips for a reason! What was the average size of the pieces/slices of firebrick you used? The residual heat curve you have achieved is highly enviable.
Great-looking pizza bread, too. I had no idea you could get a crust like that.
John
The bread crust and crumb were excellent!
John
I used a homebrew skim coat then added firebrick slices from all the dome cuts, embedding them in the skim coat
John
After the pizza party I dug into the refrigerator the next day and got out the containers of bread dough I made the Wed. before the Friday pizza. Shaped them, let them rise and put them into the oven which was around 540 F by that time. Here are some pics, I was tickled pink with the results, I did not add steam to this bake as I wanted a bench mark to compare steam results. I have made these breads many time in the home oven. These browned and bake totally evenly and the oven spring was the best I have ever had. They tasted great! Can you tell I love this oven already! I was prepared for a much steeper learning curve (more burnt/ruined dough) but this hopefully isn't beginners luck!
Again Thanks to all that have helped me with all your indepth posts and pics!
John
Olive rosemary bread and Italian bread pics
Originally posted by Lburou View PostWoW! That, I believe, is akin to getting 50 miles per gallon with a Mack Truck!
Are you measuring the temp on the floor or the dome?
I felt that pizzas would do well with the heat reflecting off the dome, while the heat still soaked in the extra mass. The hearth I left at one firebrick thick for two reasons, 1) quick heat up for pizza and reheat for next pies being cooked. 2) for bread baking I didn't want burnt bottoms-heat would be diminished quicker on the bottom with less mass than the rest of the oven. I also thought that the dome would capture more of the heat from the wood as it is always being hit with flames!
I am obviously very pleased with the results so far!
Originally posted by Aegis View Post....snip....The oven insulation so far has been fantastic! The next day temps were 585 F and this morning I am still at 370 F .....snip......
Are you measuring the temp on the floor or the dome?Last edited by Lburou; 10-01-2011, 05:35 AM.
