Cracks!! Are yours this bad??
  • breakn
    • Nov 2009
    • 20
    So I read a bunch of threads on cracks and everyone says its okay and that it still cooks great. But in the limited pictures that I see they are always small and usually in the arch. I just finished curing and have hit 900 degrees after 9 days
    I have one that is small but goes from one side of the arch to the other side of the arch all the way around in row 5 horizontally.--Im not to worried about that one.
    I have a large one that goes from the 2nd row vertically to the keystone and half way around the keystone. I can see the fire inside through this one. -- This one worries me.
    Im not worried about it falling apart or caving in but I am worried that for some reason the homebrew mortar wasnt right or anything else that you guys might bring up. I just need reassurance that this is indeed common or at least it wont be a problem
    all the cracks get bigger as it heats up.
    I have a few other small ones throughout.
    I did 1/8 mortar joints throughout. Let me know what you think
  • Les
    • Sep 2005
    • 2945
    Re: Cracks!! Are yours this bad??
    The fact that the cracks are going 2-3 bricks up in a straight line implies you you didn't alternate the bond. Ideally, the end of a joint ends in the middle of the adjoining brick - that is the strongest scenario. I don't think it is caused by using the home brew. I use the same, and I am very pleased with the results. With that said, I have seen far worse cracks - up to 5/8 of an inch. I suggest you wrap it with a blanket and call it good. As you mentioned, it will not fall apart or cave in. It will serve the purpose - enjoy the food.
    Les...
    • Mike D
      • Oct 2010
      • 342
      should you put a layer of mortar on top of it when it is cold? What about some type of bonding cement layer?
      - just trying to brain storm.
      Mike
      • brickie in oz
        • 3445
        In the first pic where your finger is it looks like a brick has cracked.
        If this is right Id make a guess that you have foundation failure, could be you concrete slab has failed?
        • breakn
          • Nov 2009
          • 20
          Yah i staggered the bricks there are 2 on that crack that are within 1/2 inch of each other. I am going to use 3 layers of blankets on it.
          Where my finger is only the small corner of it cracked. the foundation hasn't moved and the first 2 rows dont have cracks in them
          • brickie in oz
            • 3445
            The higher up you go the more pronounced it will become.
            • breakn
              • Nov 2009
              • 20
              where my finger is is the worst gap the crack gets smaller as it goes up from there.
              • Laurentius
                • Nov 2010
                • 923
                I think the key word, that Brickie used was (become), not (is).
                • Paul in Rockwall TX
                  • Nov 2010
                  • 52
                  I like the crack thread - I'm still curing and have some hairlines outside on the mortar, nothing visible inside (but it is coverered with soot because I haven't got that hot yet).
                  I like the thread because I've really had to dig for detailed crack talk. sorry I don't have any specific advice - but I appreciate you starting the thread.
                  • cvcrash
                    • Jul 2010
                    • 19
                    what was the ratio you used for the home brew mortar?
                    • breakn
                      • Nov 2009
                      • 20
                      1:1:3:1-lime, fireclay, portland, 3 parts sand
                      • Neil2
                        • Oct 2006
                        • 1374
                        Soak the crack area, patch up with very wet mortar, and carry on.
                        • DaveW
                          • Oct 2009
                          • 200
                          This baby goes up one side and down the other. It happened after I insulated the oven so I left it alone. The smoking gun in my case is is the off bond brick pattern.
                          Dave
                          Album: http://picasaweb.google.com/fornososo/Pizza#
                          • Mike D
                            • Oct 2010
                            • 342
                            What about putting a layer of Wellbond (construction adhesive) over the whole thing like peterlyn did in the Pompeii in Nanoose Bay build (post #9) .http://www.fornobravo.com/forum/f8/p...bay-14633.html
                            I know nothing about this at all, I just saw it in the thread and was thinking about it.
                            Mike
                            • Ken524
                              • May 2007
                              • 1655
                              If you patch it from the outside (or inside) it'll likely just crack again during the next heating/cooling cycle. What you have there is a naturally occurring expansion joint
                              Insulate and start making pizza! You are good to go.
                              Ken H. - Kentucky
                              42" Pompeii
