28" Pompeii
  • ggoose
    • Sep 2010
    • 202
    #91
    Re: 28" Pompeii
    Thanks Russell. The door turned out nicely. Last night, two full days after making the pizza, the oven door thermometer still registered over 200 degrees. The oven appears to be holding heat well. Hopefully I will get the final coat of stucco on this week and the oven will be complete...
    gene
    • dsm
      • Nov 2009
      • 96
      #92
      Re: 28" Pompeii
      nice looking oven also, did you finish the stucco yet?
      Picasa photo library:
      https://picasaweb.google.com/1043493...lleryMay192012
      • ggoose
        • Sep 2010
        • 202
        #93
        Re: 28" Pompeii
        Thanks.
        Not yet...the finish coat was special order; should be here by Thursday.
        • dsm
          • Nov 2009
          • 96
          #94
          Re: 28" Pompeii
          hey ggoose what did you use for the brown coat ?
          • ggoose
            • Sep 2010
            • 202
            #95
            Re: 28" Pompeii
            Just some leftover type N mortar from adhearing the cultured stone and brick to the base...
            • Pompeii Nate
              • May 2011
              • 219
              #96
              Re: 28" Pompeii
              Hey Gene,
              I have another question for you. What did you do to secure your countertops to the oven? I have been thinking of a couple options but I am curious what you did.
              Nate
              http://www.fornobravo.com/forum/f8/p...two-21068.html
              • ggoose
                • Sep 2010
                • 202
                #97
                Re: 28" Pompeii
                Nate,
                Since that area wouldn't (shouldn't...doesn't) get too warm, I just used silicone caulk beneath and between the counters. The ledge extends out far enough to almost completely support the bottom counter, so gravity is doing most of the work. The brick arch facade and stucco, along with the caulk, just prevent any lateral movement.
                gene
                • Pompeii Nate
                  • May 2011
                  • 219
                  #98
                  Re: 28" Pompeii
                  Thanks Gene. That's what I was guessing. Once again, it looks great!
                  Nate
                  • Aegis
                    • Jan 2008
                    • 436
                    #99
                    Re: 28" Pompeii
                    Originally posted by ggoose
                    I was asked the dimensions of my oven:
                    Inside dameter: 32"
                    Interior dome height: 16"
                    Oven door height: 11"
                    Oven door width: 16"
                    I cooked my first pizza last night. Just a simple cheese pizza; it cooked in 4 minutes . As a side note, the oven temp this morning was still at 350 degrees, so I made some blueberry muffins; they came out great! This may become addicting...
                    gene
                    Great job! And is there really any doubt about the addiction????
                    • danhem
                      • Feb 2020
                      • 105
                      #100
                      Re: 28" Pompeii
                      More progress today. I completed the outer arch and chimney transition. I have a bit of cleanup to do on the under-sides of the arches where the forms were; I suppose I'll take the grinder to it unless someone has a better method for cleaning hardened mortar. At any rate, my seven day drying clock has started and my curing fires should begin right after that...
                      Been through this threat, great job on the build.
                      I see that your outer arch is slightly wider than this inner arch - is there a functional reason for this or is it purely aesthetic?
                      My Build:
                      https://community.fornobravo.com/for...and#post423032
