Is Mortarless Realistic?
  • GianniFocaccia
    • Jun 2009
    • 1645
    In reference to the recent thread 'To taper or not to taper' located here:
    cholme illustrates profiles of three kinds of dome construction styles: mortarless, tapered with mortar, and untapered with mortar.
    Because I have yet to see a true mortarless oven on the FB site (precast ovens don't count) I am wondering if this is an ideal or truly possible (transition construction and stability nothwithstanding).
    Further, since mortar seems to play an important flexural role in the dynamics of an expanding/contracting dome (in addition to it's static stability), is it possible to go 'semi-mortarless? This would be where the inside/outside joints reveal no mortar, yet there is a small cavity between bricks that contains 1/8" or so of mortar to keep the bricks stable when going vertical during construction.
    If someone has built a truly mortarless oven I would love to see pics of it.
    John
  • SCChris
    • Jun 2009
    • 1213
    Re: Is Mortarless Realistic?
    John,
    My answer is "No" it's not realistic, but it can be done..
    As you know I tapered and used mortar. My reasoning has always been that the dome is just a pile of bricks that are self supporting and mortar fills the gaps. I feel that if every brick is tapered and is always being pulled inward because of the taper shape and gravity, then even if cracks are present and mortar isn’t, the structure is sound. Now this said, I’d hate to try to keep a mortar-less dome oven, built with straight cuts, hot. I haven’t seen an oven in FB that didn’t need some mortar. I can imagine 2 ways to build a mortar-less oven.
    1: Cast different bricks for each course this would allow the bricks to match the surrounding tightly on the four contacting faces.
    2: Use a wire saw to cut each brick. The wire saw can cut the cone of each course and the sides of the bricks without gaps. Of course, gaps would occur anyway due to the differing particle size and density of the bricks and each brick, but I think a free standing dome could be built with a wire saw in a timely manner. I’d still insulate the H E double toothpicks out of it.
    It’s fun to think of the alternatives, but without the resources and time.. Sigh..
    I'd love to have an endless R&D budget. Come to think of it, I'd just be happy to have a budget..
    Chris
    • cholme
      • Aug 2007
      • 62
      Just to clarify, the drawing I posted with no mortar was not to propose a "mortarless" dome, just to illustrate that if you did taper each brick to fit the arch, you would possibly have more of a mortar joint inside the oven than with square bricks.
      I would concur that a mortarless oven would be a bad idea.
      • Les
        • Sep 2005
        • 2945
        The dome could be mortarless but I think you would need some to tie in the arch. Even this area would be possible but it would require a fair amount of engineering time (not to mention the crazy cuts I envision).
        • gt40
          • Apr 2011
          • 91
          This is the closest to mortarless I have seen:
          STOVEMASTER - News
          49" Recirculating LOW DOME Pompei build with welded stand:
          http://www.fornobravo.com/forum/f8/g...log-15903.html
          • ggoose
            • Sep 2010
            • 202
            Impressive build gt40...
            • Ken524
              • May 2007
              • 1655
              John, check out Les' semi-mortarless oven.
              Amazing work.
              Ken H. - Kentucky
              42" Pompeii
              • GianniFocaccia
                • Jun 2009
                • 1645
                Right on, Ken. I had replied earlier to gt40's Stovemaster link but for whatever reason it didn't go. It went something like this:
                gt40 - that's the prettiest oven I've ever seen except, uh, Les' build...
                  Best transition I ever saw:
                  • Tscarborough
                    • Oct 2009
                    • 3341
                    That is a thing of beauty, it is called a jack arch.
                    • SCChris
                      • Jun 2009
                      • 1213
                      I’m not aware that any of us in the conversation is a professional Mason and a “Certified Heater Mason” in addition. This is in mind, I think we all fare pretty well for a bunch of rank amateurs. The Stovemaster oven, is very clean I wish he was my neighbor during my build, if for no other reason than to get a bit of feedback from time to time..
                      Kudos to all!
                      Chris
                      • Tscarborough
                        • Oct 2009
                        • 3341
                        I am not a professional mason, but I am a masonry professional. In theory, there is no particular reason you could not build a mortarless oven, entryway included, but practically, you will always have some gaps. Gaps=leakage, leakage=erosion, erosion=fire hazard.
                        Mortar is to hold the bricks apart, that is, to allow imperfect units to be used to create a solid wall.
                        • SCChris
                          • Jun 2009
                          • 1213
                          Tscarborough,
                          I salute you!! I saw your post show up in the thread just after I hit the post, you beat me to the post.. I remembered that you had more direct mason experience, and didn’t remember immediately to what depth. No slight meant to you or other real masons in FB at all.
                          Sincerely
                          Chris
                          Learning is expensive, ignorance is even more so..
                          • asudavew
                            • Jul 2007
                            • 1880
                            Design Squared: Yours Trulli, third in a series on Vernacular Architecture
                            My thread:
                            My costs:
                            My pics:
                            • Les
                              • Sep 2005
                              • 2945
                              Wow Dave - it's been a while. Or have you just been lurking?
