Johnfm43 Build
  • #16
    Re: Johnfm43 Build
    Yes. It has been a few weeks since I have done anything on it. As you might have read under the insulation Thread that I posted, I messed up on the thickness of the insulation layer. I am waiting until I get Fiber board insulation before I can go any further.
    Also I am the Head Football Coach at the local high school. We have been going non stop for the past 3 weeks. The school that I teach at uses a modified year round schedule. That is six weeks on with one week off. So teaching and double days of football has put a stop to all progress. The month of September might be better.
    • #17
      Re: Johnfm43 Build
      Ok it is time to get started again. I think that I will try and set the record for the longest time to build an oven. I have had several things impede my progress over the past 2 years. I hope to make some good progress over the next three weeks before I go to Alaska to work for 35 days. My goal is to finish by Sept 1. But, not saying what year. I will post pictures soon.
      • #18
        Re: Johnfm43 Build
        I am need of some help. I have put in the solider course and tried to cut the halves to fit tight together. But even as close as i cut them it still appears that there is some small gaps. I did not put mortor between them I am planning on laying several layers of insulation and stucco. Should I take them apart and install mortor between them to insure no gaps?
        Johnfm43
        • #19
          Re: Johnfm43 Build
          glad to see you are starting up again. it's exciting once you get the dome going.
          regarding the mortar, I did not mortar my floor but did use refrac mortar on everything else, including my first course. My dome bricks were not precision cut as I did used headers, so I had big gaps to fill.
          What helped me was to set a deadline for completion of my oven. Funny how it came together as it is a lot of work. I had all kinds of help and supplies turn up when least expected, but I kept focusing in on my completion date. The old "write down you goals" and they do come true.
