Re: Cloita's 42" Pompeii in Plainfield, IL
bump for any input on stucco, thanks!
Ok so I'm to the point of making a decision on my aesthetic finish.
I've framed out the walls and roof, i have a bit more framing to complete to make sure the structure is as rigid as possible:
I was originally thinking of covering the base with a stone finish, then stucco on the upper half. Anyone have recommendations on stucco on concrete board or finishes for the roof? I've seen slate roofs as well as traditional shingle. I'd love to hear from anyone that has used stucco for both roofing and siding. Thanks!
first standing rib roast in the WFO. mmmmmmmmm char!
and google plus auto motion images are amazing...
Look at aceves his is cool.
lazy summer! been using the hell out of the oven at least.
Hey-glad your back!
Keep up the good work. wont be long now!
Texman
Thanks ggoose, i've ran with that idea and started planning for it.
As far as framing goes, we've got walls:
Next step is the roof. Going to call in a pro for this since we couldn't decide on the best way to pitch it back in this corner installation.
You could always continue your masonry work on the arch bringing forward and into plumb with regular bricks; the final outer arch could be a bit larger (than the firebrick arch) and run the framing to it...
Anytime, thanks for the inspiration. Good to see you're back at it!Originally posted by johnfm43 View PostCloita's. Thanks for giving me credit for the base and concrete design. But yours looks mutch better than my concrete work. You have also made much more progress than I have so far.
Looks great so far
Johnfm43
After much procrastination, research, then more procrastination, it's now June and time to actually do some building this year. One of the last pieces i'm trying to find good information on is how to tie the enclosure into the arch. Any suggestions on whether i should frame right up to the firebrick with my enclosure or should i reveal the ugly arch? One issue is that the front of my oven isn't exactly plumb, the arch juts out a tiny bit. Been pondering if i should risk grinding it level or what i can do to bring the enclosure up to it.
Any thoughts are appreciated!
Looks great so far
Johnfm43
Thanks, hopefully make some progress tonight. Going with tall enclosure with flat roof pitched backward, possibly stucco or copper siding for the finish but unsure with that.
Chicago Deep Dish Pizza
Dough:
2 packages quick-rise dry yeast
2 cups warm water (90 degrees F)
1/4 cup olive oil, plus more to oil the pans
1/2 cup yellow cornmeal
5 1/2 cups bread flour
4 teaspoons kosher salt
Dissolve the yeast and water in the bowl of a mixer fitted with the paddle attachment.
Add the oils and mix for 30 seconds. Add the cornmeal, 3 cups of the flour and salt and
beat for 5 minutes. Switch to the dough hook and mix in the remaining 2 1/2 cups of flour
and knead, using the dough hook for 2 minutes.
Place the dough in a large bowl lightly oiled with olive oil, cover with plastic wrap or
clean kitchen towels and let rise in a warm place until doubled in size, about 45 minutes.
Punch down the dough and allow to double in size again.
Cook time/temp:
I'm still learning on this. I also use instant yeast and my caputo 00 flour instead of quick rise dry yeast and bread flour. I've done 550-600 in the WFO for 25 min and gotten a black disk, i've done 375 for 45 minutes with a conventional oven and gotten squish. Would recommend 500-550 in the WFO at this point and trust the top - when it starts getting dark, the rest should be done too. Good luck!
Hi Jonathan,
Excellent work on your build! Keep working on it, or it might take you a while finish it!
Any thoughts on your enclosure design?
Also, can you throw us a recipe for your Chicago-style pizza? Ingredients, temps, time? I definitely want to try it!
Aceves
Did a little reading and efflorescence matches up with what I'm seeing. Only time will tell if it harmed it structurally I guess. Thanks!
I removed any loose cladding before I put the insulation on. Moving on to the enclosure.
Looks like efflorescence...I don't think it will bother your oven too much. The cladding looks like it can be easily removed/replaced, though I don't see where that will hurt anything either if you just left it alone; it adds no strength, only mass.
