To Grind or not to grind
  • woodfried
    • Jul 2010
    • 44
    Hi All
    Well im 1 course away from closing the dome and whilst inside cleaning off mortar im looking at a few bricks over the transition that stick out here and there by 10 -15mm . Can i grind them back level or should i just leave them ?
    anyone got an opinion?
  • GianniFocaccia
    • Jun 2009
    • 1645
    Re: To Grind or not to grind
    Just like a flue, I believe an oven will operate optimally if it has smooth surfaces and protruding 'obstacles' are reduced as much as possible. Since you've put so much time and care into building your oven, why not tune it up while you still have the chance?
    • eprante
      • May 2009
      • 282
      I wouldn't bother. If it is in the transition area it isn't going to be seen or create any type of problem.
      Eric
      • woodfried
        • Jul 2010
        • 44
        Thanks for that, I suppose Im more concerned that the ground surface of the brick would be less heat resistant than the un cut fired outer surface??
        • GianniFocaccia
          • Jun 2009
          • 1645
          Look at Les' build. Every brick facing the inside of the oven has been meticulously cut.
          • woodfried
            • Jul 2010
            • 44
            very true , I gave it a tidy up and its much better!
            • GianniFocaccia
              • Jun 2009
              • 1645
              Excellent! The only one who has to know is you.
