I am ready to place my insulating blanket and was wondering how to hold it in place until I get the chicken wire mesh installed. I thought about duct tape but was not sure if it could take the heat or if I really needed it?
Insulating blanket
Tags: None
Re: Insulating blanket
There is probably a very simple way of doing this tucked away in a thread somewhere here, but I just drilled a few holes into my slab and put in some hooked screws using the green plastic 'spaghetti' to fix the screws into the concrete. I spaced these hooks evenly around the perimeter of the dome wall, about 20mm off the brick face. Then I just used some galvanised tie-wire from the local hardware store and fastened the blanket down with that, using the hooks as anchor points. That's one way! -
Thanks guys for the suggestions; I am getting close and it is very exciting.
Greg:Comment
I found any of the insulating blankets will stay in place and will have minimal movement. I think I wound up using four different brands, I went with the best deals, (ebay,craigslist,on-line orders) to maximize the amount of insulation. You can never have too much insulation! On the other hand I over spent on safety devices as in a respirator etc. You can never filter the air you breathe too much!Comment
