Hi everybody
wonderful group you have here. I hope to join the ranks of you builders soon!
I'm in the research/design phase presently and have a few questions if I may (not sure if this is the best section to ask but here goes...)
I have an existing slab/foundation from a pump house I tore down. I would like to use the existing slab as partial footing for an exterior facing corner oven. The future oven will be a part of a new wood framed building (not attached to the house) already under construction. I am nearing a descision point as to framing material near where I will eventually site (hopefully this summer) the WFO. Generally speaking, what is a safe distance for combustible materials such as wood framing near the oven opening? My new building is octagonal with 8 foot wall widths, 8 feet tall, and 2 foot roof overhangs . The oven design I am considering would have the oven opening very close to one of the exterior coners of the octagon. In anticipation for the oven, I built one of the walls of concrete block but the other is to be framed in part with wood. I am considering a wood beam over the oven to carry the rafters and filling in the opeing with metal studs. When ready to build the wfo, I would remove some of the metal studs and fill in with masonry. Not sure any of that is at all clear and I'm sorry I don't have a plan drawing to help communicate. Basically, a block wall on one side and metal studs under a beam on the other. The question is - how far to the (left) side of the oven should I run the metal studs before transioning back to wood? Is the wood beam and wood framed roof overhang also a potential danger and something I need to consider? Speaking of that beam...because the site is sloped and the foundation raised, the the distance from the top of the oven door to the bottom of the beam is estimated to be a little over 5 feet
I know that codes will differ by region, I'm just wondering if there are some common sense guidelines (erring on the side of overkill) that can be followed so that when I get going on the oven I don't end up having to change a lot of structure on the building. It would be a nice location but if fire danger makes this too complicated. I'll just have to plan for a stand alone oven site
thanks so much for reading all of that and thanks in advance for your thoughts and advice.
John
John
