Mississippi 44" - Forno Bravo Forum: The Wood-Fired Oven Community
Mississippi 44"
  • Mississippi 44"
    Thanks eveybody for your pics, ideas and Forno Bravo for hosting this site. It is unbelievable how much information is on this site. And learning from so many who have first hand experience is priceless. I've learned from your success's now maybe some one can learn from my mistakes.:
    It's raining, every thing is covered up, and I'm out of brick. So I guess it's time to figure out this photo posting stuff and start chronicling my build.
    I started a Picasso album and it looks like the link works in my signature. I'll figure out the rest as I go. I may have to edit this original post so please bare with me as I learn.
    I began a hearth set into a space left in a retaining wall that I had originally meant for a BBQ pit. That space seems to be just right for the WFO. All but about 8" of the hearth stand will be below grade. I hope with the plastic underneath, surrounding the block stand and along with the sandy soil that moisture is't a problem. If it is I'll just get the shovel back out and install a french drain like I should have to start with.
    Since the storage can only be accesed from the front I became conserned about clearance underneath the stand. I wanted a center support and that also seemed to make the back of the storage area more unaccesable. I did not want to add a half row of block thinking that that would make the landing higher than I wanted.
    I decided to not use angle iron to support the lintel blocks and went on to pour the lintels and the hearth monolithic. I formed an arch over the opening lintel and the center support lintel. This will give me about four more inches of head room in the very middle.
    joe watson
    My Picasa Web Album
    Re: Mississippi 44"
    Poured 4" of 5-1 vermicrete on the hearth. I had figured that it would take seven cubic feet of vermiculite. I bought two 4cubic feet bags. That was'nt enough. I lacked about 1/2" across the entire form. The nursery closes at noon on saturday. No other source for the course grade so I had to settle for some expensive horiculture grade vermiculite from Walley World. It is a lot finer than I wanted and I'm sure that it is as not as good as an insulater. It did make a smooth compact surface though. If had it to do over and vermiculite was going to be my only floor insulation I would fab a 1/2 deeper form and pour this stuff for a top coat. It firms up the surface.
    joe watson
    My Picasa Web Album
      Re: Mississippi 44"
      Started out to build a 42" pompeii, but I ended up laying out for a 44". The 42 just looked small on that big hearth. It may not be a true pompeii when finnished though. I am thinking about gradually pulling the dome back in to about a 20 to 21" at the apex. (Any and all suggestions welcomed)
      After a few unsuccessful attempts I finally found something from which to fab a dome guage. The pivot is from an old commercial door closer. It happened to have the same threads as a large turnbuckle that I picked up at Ace hardware. Along with a short piece of allthread I had an adjustable dome guage.
      I had took the time to build a plywood floor that would be removable when finnished. I had the dome guage attached to it but It was warped. I sacrificed a brick to keep the exact center built a wood brick to replace it as stable anchor for the guage. Now the box for the HF saw has a new use covering the oven floor.
      No welding
      joe watson
      My Picasa Web Album
        Re: Mississippi 44"
        I built the inside arch first and tied it in with the first three rows of dome brick. (no soldier course) I was thinking that it would lean in more than it does in order to match the curve of the dome. I felt that it would need the support at the base as it would be standing alone temporarily. From the photo below you can also see that I ended up with 2" of CalSil. (I'm glad that I did not add a 1/2 row of block to the harth stand) The CalSil was given to me and I was also glad to find out that it is great insulation for the oven floor. I will have to extend the vermicrete and CalSil out a little further to include 2 full brick for the flue.
        EDIT
        I knew from reading many builds that there would be a problem keeping each row level as it tied into the curve of the entry arch. I decided to concentrate to completely finish the dome/arch tie in before completing the remainder of each row. I laid just enough brick of each row to allow me to rack back the next row. This left the back of the dome open to allow me easy access to make these difficult cuts.
        I must admit that I did not really think that this really going to be a problem, but I discovered that I too was dropping as much as 3/16 of an inch per row tying into the curve of the arch. Being forewarned by studying other builders projects helped me catch this early.
        I then found a use for a tool that I have had for a long time but had not got much use out of. That would be a laser level. It worked like a charm. I set it up just out side of the back of the oven directly opposite of the arch. I found that if I set it up back far enough, its beam shown on both sides of the arch. Using the dome gauge I would set a brick on each side of the arch for the row that I was working on. I then adjusted the level to the height of the bricks. Surprisingly they were always at the same level. This gave me a reference point to work back into the arch.
        I wished that I had got more pics, I hope this explanation helps.
        Someone else may have already be using this technique. If not here it is. There is probably a better way out there, but this worked for me.
        I cleared the arch with the 9th row. Didn't get many pics as I was trying to beat the rain last night. I will get more when the weather clears.
        Another edit
        I felt like that I needed to go back and clarify what type laser level that I used on the build. Mine is a rotating, self leveling, cross projection laser . It is not the type that you mount to the surface that you are working on like those used for hanging pictures. It has to be set back away from the project. The picture hanger stud finders are useles so I have been made aware. I think that you can tell what brand from the pic.
        The further you set it back from the project the wider the beam. If you set it back to far though, bright sunlight will obscure the beam. It can be placed on a stand or (as I did) set on an ever increasing stack of bricks. This is the only laser level that I have ever worked with and did not think about the different types that are available out there.
        joe watson
        My Picasa Web Album
          Re: Mississippi 44"
          I'm still working on including photos in the post. I've tried the fixes and the tutorial. I'm not sure but it may be that I haven't reached the minimum number of posts. I have some more pics on another camera if I can get it to be recognized by this computer. I'll add them to the Picasa album if I can.
          joe watson
          My Picasa Web Album
            Re: Mississippi 44"
            It looks great so far. Where are you in Mississippi?
              Re: Mississippi 44"
              Thank's Tscarborough
              I'm in southeast MS. I usually start out answering that question with the nearest large town. That would be Hattiesburg. If someone is a little more familiar with the area I tell them the nearest small town. That would be Richton. To be exact I am from a very small community in Greene county called Piave, MS.
              joe watson
              My Picasa Web Album
                Re: Mississippi 44"
                Too small for me to know. I am from Gulfport, my wife's family is from Hattiesburg and my parents moved back to Woolmarket (Biloxi) when my Grandmere died.
                  Re: Mississippi 44"
                  Use Pixresizer (google) to make the pics 800 pixels wide, thats the biggest problem with up loading pics, and the fact they are 1.2 Million pixels in size.
                    Re: Mississippi 44"
                    Yea, that's why I start out with Hattiesburg I began this post also to tell you that I was born in Houston,TX. I first read your location as Austin. I did not get a hit on googling "ausitn" though. Not trying to replace "Brickie" as the "spelling police" for the site. Is that a misspell?, or is that in another country?
                    We love the coast and everything about hiway 90. All the way from New Orleans to Pensacola. Love riding down there.
                    "Pizzaa Anarchy" COOL. I like that. I will book mark that so that I can find it when I am done with "take out" and "Hunt's Brothers".
                    joe watson
                    My Picasa Web Album
                      Re: Mississippi 44"
                      Thank's "Brickie". I apoligize for that remark above, although "It wasn't me"
                      I have been trying a test pic that I have reduced down to 500 by 332 pixels. I am not sure but I am hoping that the number 25 posts, which will promote me to pissant, I mean peasant will be the trick
                      If not I will, I will start again to seriously find a fix.
                      joe watson
                      My Picasa Web Album
                        Re: Mississippi 44"
                        Austin Texas, although I have lived all over the US from Anchorage Alaska to Ft Lauderdale Florida and everywhere in between, including high school in Nassau Bay TX (South of Houston). I am a construction brat, son of a Civil Engineer that excelled in advanced and technical PIP concrete.
                        Sort of Ironic that I have gone into unitary masonry, actually.
                          Re: Mississippi 44"
                          Two of my older brothers played left and right half backs for CE King back in the late 50's, their junior and senior year respectively.
                          Our dad was a general contrator. We learned to do it all from digging the footers to building the cabinets. Swore that I would do everything I could to get away fom it. Now, I do as much of it as I can in my spare time to "get away from it all"
                          Now that is "ironic"
                          joe watson
                          My Picasa Web Album
                            Re: Mississippi 44"
                            Thank's Brickie,
                            I did not use Pixerersizer, but I did use your suggestion to resize my pics and I was able to upload from my computer using the "thumbnail" method (paperclip). I'm still not able to do a direct insert using Picasa though. I am beginning to think that it is a Picasa issue.
                            joe watson
                            My Picasa Web Album
                              Re: Mississippi 44"
                              I uploaded a pic from my first post which had been reduced to 800 wide to photobucket ( I use this site for my bike forums). No problem. I was able to do a direct insert. I will slowly go back and edit my posts. Later! though, it's supposed to be a pretty weekend for December and I am going to work on the oven
                              joe watson
                              My Picasa Web Album
