Re: 39" Stargate Pompeii
"I guess I can make two mixes at once"
This is what I do. Two mixes, one for the narrow part of the joints and one for the wider parts. This also minimizes cracking.
. Then I had to cover for rain. We are lucky with weather though. Even Rome is covered in snow. Rugby was cancelled in Paris as pitch was frozen.
) I could have done with much fewer cuts. I cut each brick for the arch with 3 cuts. With the new method I could have cut two arch bricks with just three cuts - and reduced wastage.
Solution will be posted at the end of the build.
There - I actually drew that using the same wooden jig which I used to cut the arch bricks - just slid it towards the middle.
wipe that.
