Re: 39" Stargate Pompeii
Just to clarify (correct?) what I said in the last post:
This is roughly true if you are using same size - say 1/2 size bricks. As the brick sizes get smaller - to 1/3 for example - the angle front to back gets smaller also but will not change just because you go up the rows, so a 1/3 size brick on row 1 could be cut at the same angle (front to back) as a 1/3 size brick on row 6.
Aidan
My mistake was thinking it should change as the rows went up because the circle gets smaller
Aidan
