Re: WFO Build in Connecticut
Understood. I just decided to build the floor inside one layer and use my original sailor course design. I am finding that over thinking things leads to no where. I just have to do it and in the end I know whatever my decision, it will all work out. Thanks again.
My firebrick chips took out the expansion joint required between the hearth and walls. CRACK, went the dome wall, and not a small crack at that! For this potential problem I would never build another this way. With the walls on top of the hearth everything can expand, even with a dash of stupidity added in like I did!
and kept stupidity out of the oven haven't had a problem with their hearth inside the walls.
. It does fit within the ratio of dome height to opening. My actual dome height may end up being 19". We will see.
