Hello Russell,
I viewed this thread and viewed our whole set of pictures and have two question:
1.) My supplier said to me, I should use oilpaper between the blanket and the vermcrete. If I got it right, it is not advised, as steam will be trapped inside. You punched your foil with holes. After several years, is there an optimal way of constructing it? Should I use this paper? Should I forget it or should I put holes in it?
2.) The second thing I could not find in the thread: What is this hole on top for? It seems as if you put a nut in the vermicrete so that steam could escape through it and then some kind of garden hose adapter or something like that on top. Is this advised? It isn't mentioned in any instructions I could find.
Thanks for your help
Jens
Jens
