Re: Wood Fired Beehive in Utah
My $0.02 on this is that if you make the bottom width of the new course the same as the top width of the last course you end up with the same number of bricks on both courses and a) your angle remains the same and b) you don't have to worry so much about staggering your joints!
of course, my sloppy mortar joints would always seem to mess up alignment for me - and I had a pretty imprecise jig system. But if you are being super precise with your cuts and are able to keep your mortar joints consistent it should work very well. I'd recommend trying that approach as the starter.
Originally posted by texman
View Post
