Need fast technical help please with crack
  • NYC
    • Jun 2011
    • 110
    Hey guys, built my oven last fall and did a small curing fire in November. Goin to get on the finishing material this week and after standing idle for six months I just lit a large fire to test it. Got a few hairlines but one 1/8" crack has developed. Not worried cosmetically as it will be covered but need advice if it will cause any structural failure. Safety first. Will try to upload a few pics soon.
  • Les
    • Sep 2005
    • 2945
    Re: Need fast technical help please with crack
    If the brick breaks it's bond on the other side it may slip a bit. I don't think you need to wory about it sliding out because of the taper. Does the crack shrink back to normal after the oven cools? I personally haven't seen that but have read about it on a few posts.
    • NYC
      • Jun 2011
      • 110
      Les, the fire is still burning. I will know tomorrow if it shrinks back down.
      • NYC
        • Jun 2011
        • 110
        Anyone can answer?
        • Tscarborough
          • Oct 2009
          • 3341
          No problem. Keep firing it.
          • Les
            • Sep 2005
            • 2945
            Originally posted by NYC
            Anyone can answer?
            I thought I did? If it opens and closes I don't think you have a problem. If it grows an eighth of an inch every time you fire - that would be a problem.
            • NYC
              • Jun 2011
              • 110
              It didn't seem to close much so I filled it with some heat stop the next day. Haven't fired it since as it has been raining.
