Now that I've finished the dome I have to plow further into unknown territory (the dome seemed like the easy part - easy to envision how to build it anyway) and I have to do the entry and chimney..and now I'm reading all these great threads trying to get a handle on how to proceed, and I'm intrigued with the ceramic insulating tape as a heatbreak.
So my first question is easy enough...how much insulation blanket should I order for a 46 inch oven? Any recommended sources?
Secondly, the flat ceramic insulating 'tape' that I've seen some use in their builds...Gulf comes to mind...I'd like my entry to be marble. Could I use that as a heatbreak between the oven floor and the marble where they would meet? Can I cut a narrow pocket out of the underside of my marble to place that ceramic tape and have only a thin section of the marble actually touching the fire brick floor or will that stress the marble too much with heat fluctuation? Is the best way to just seal the ceramic tape against that fire brick and set the marble against it so they do not contact?
Thirdly, if I want to build my entry and chimney with red brick and not fire brick, should I consider a heatbreak there too? If I build it with red brick, should I use homebrew mortar? I've been intrigued with line mortar and am considering going that route for the finish work.
Thanks!
Thanks!
