So after over a year of constantly reading through others' build threads and asking a ton of what I am sure were annoying questions I have finally started my own Pompeii oven. I am excited to get started and I hope I can do half as well as all those I have been studying. So here it goes...
I started by digging down about 15 inches into the compacted clay we have here in Eastern Idaho. I started with my cousin's rotor tiller by loosening up the ground then shoveling it out but then after about two passes with that and about 5 inches down the tiller broke when I was turning a corner and ALL the oil poured out of the engine and into my hole. I felt horrible. (Luckily my cousin is a very resourceful guy and he was able to fix it as soon as I took it to him). I finished the rest of the dig with a shovel and it almost seemed to go easier than the other method.
After I got the hole dug and leveled I took a compactor to it but I really don't think it did a whole lot since the ground here is really compacted. I then added pea gravel about 4" at a time then ran the compactor over it until I had about 12" of the compacted pea gravel. The last three or so inches was reject material and again I compacted that down so that it made a pretty solid base. In reality, I did the last three inches of reject material because my neighbor got me worried when he almost laughed when I said I was using pea gravel. So instead of using all pea gravel I compromised and used the reject material for the last few inches. Anybody see any problems with this? I guess if you do it is too late now but I am interested in your thoughts.
I put in conduit for the time in the future when I can afford to tear up my backyard and patio to run power to the oven but for now I don't have that money. The conduit is about 12 inches deep and I have it running about 10 inches beyond the concrete foundation so that it will be easier to find when that time comes.
Here are some pictures of these steps.
Comments and critiques are always welcome.
Nate
Nate
