vent chimney ?
  • dsm
    • Nov 2009
    • 96
    vent chimney ?
    Hello ,, is it ok to vermiculite and portland mix the whole vent and clay flue in,meaning frame around it and and filling it in with v/p mix..
    Thanks ,
    Dave
    Picasa photo library:
    https://picasaweb.google.com/1043493...lleryMay192012
    Re: vent chimney ?
    Yes it is OK, if fact it is a really good idea, because although you don't really need to retain the heat in the flue and the entry it will both support the structure and reduce the temperature differential between the inside and the outside which can be damaging.
    • dsm
      • Nov 2009
      • 96
      Re: vent chimney ?
      Ok great that is why I wanted to do it mainly for the support to hold it all together.thanks david .
      • dsm
        • Nov 2009
        • 96
        Re: vent chimney ?
        vermiculite and portland mix ready to go...
        • dsm
          • Nov 2009
          • 96
          Re: vent chimney ?
          vermiculite/portland mix ready to go
          • Les
            • Sep 2005
            • 2945
            Re: vent chimney ?
            Dave,
            I laid my decorative brick about an inch from the flue pipe and worked the vermiculite / portland in between the two. You are obviously using a form so what is your plan on the finish? The route you are going, you could pretty much do anything. Great idea, opens up a LOT of potential.
            • dsm
              • Nov 2009
              • 96
              Re: vent chimney ?
              The forms are off. I am thinking of a enclosure les, i v/p the vent for structure and insulation purpose. I am pretty much winging it, i have been making up ideas as i go on, every time i have a idea i change it anyway,lol...so will see where it goes from here.
