Re: Under way in Socal
1st: Congrats on finally getting the oven started with a real completion date.
2nd: (if it's not too late) YES, a GOOD 1/4" is important. I mean, I've not gone into my dome with a micrometer but I just know there is that much expansion and since you appear to be leaning toward a reall soldier coarse (on-end brick surrounding the floor) use the double corrugated cardboard strips to get your 1/4" spacing from the herringbone floor.
Glade you are going with a flaired entry, for the tiny bit more work, you'll be glad you did.
Also, if I had it to do all over again, I would have taken the time to put in an expansion joint like John did, (to isolate the oven from the inner arch and vent box) but it will slow you down to stop and think and do some designing. I get the same way about having a thermocupler in the brick to temp the saturation. But, I don't have them and love the wfo just the same
Lot's of luck and have fun building it.
-Dino
-Dino
