Floor insulation question
  • pdqtom
    • Dec 2011
    • 58
    Bummer,
    I think the fiberboard I got for my build is the wrong material. It is compressible and not very rigid. I am curious if Insulating Fire Brick, "IFB", can be used for floor insulation? Seems I saw something about using it under the floor is OK. But can't find it now. Any opinions or thoughts about using IFB for that purpose. I can get them for $28.50 per case of 10.
  • GianniFocaccia
    • Jun 2009
    • 1645
    Re: Floor insulation question
    Vermicrete has the same insulation properties as IFB, only cheaper. You'll need twice the depth of vermicrete/IFB as fiber-board to get the same insulation value. Get the proper board if you can. Try Harbison Walker (anhrefractories.com) in Dallas. A number of builders have used their Insboard 19.
    Dallas, TX 214-330-9243 214-330-6085 Renee Fouts
    4585 Mint Way Willie Edwards
    Dallas, TX 75236 Joe Lloyd
    • pdqtom
      • Dec 2011
      • 58
      Thanks Gianni, I'll give them a call first thing in am. I have been to their web site and did not get much info out of it.
      • pdqtom
        • Dec 2011
        • 58
        Harbison Walker did not work out, their minimum order is over $600. Ill keep looking.
        • texman
          • Nov 2009
          • 724
          I purchased FB board from our host and had it shipped to Texas. Tscarborough in Austin may have a source, check with him.
          Good luck, finding the right material is one of the challenges of building the WFO correctly. Take your time and get the right stuff.
          Tracy
          Texman Kitchen
          • pdqtom
            • Dec 2011
            • 58
            Mucho Thanks to Texman!
            After a couple of person to person e-mails, I believe I do have the right insulation after all. Gave me a scare though.
            All the help available on this site is unbelievable. As soon as I mortar the first two brick together it will be my first two ever!
            Thanks to all and especially Texman!
            moT
            • brickie in oz
              • 3445
              So vermicrete really has half the insulating properties...
                It depends on how much cement it contains. The higher the cement content the higher the conductivity /lower the insulation value.
                  I updated the results of my vermicrete slab drying experiment which shows a water loss of some 75% over a four week period in uncovered, ideal drying conditions. Make of it what you will.
                    ceramic blanket K value (thermal conductivity) around 0.04 (av. between #6 and #8)
                    Vermicrete 4:1 K value 0.16
                    6:1 0.12
                    8:1 0.09
                    Vermiculite alone 0.06
                    Perlite alone 0.03
                    So yes blanket is about twice as good as 10:1 vermicrete, although the values change a bit with increased temp.
                    Also note that perlite is a superior insulator on its own, although combined with cement expect the values to be much the same as vermicrete.
                    Sorry the table was nice and neat until I hit the submit button and it's jumbled it up.
