Re: Calcium Silicate board thickness
To increase the strength of that thin concrete slab you can add fibres. There are all kinds, plastic ones should be fine, the slab will not get hot enough to melt them.You can also increase the strength substantially by using a super plasticiser and an ad mix, but you will need to do some research and go to a concrete supply merchant. By making the slab stronger you can then make it thinner and save a heap of weight.
