Calcium silicate or ceramic fiber board
    • 5263
    #31
    Either works, similar in properties.
    • yomer
      • Jul 2022
      • 2
      #32
      What about having one board vs small segments to make up the area under the base?
      I found a warehouse which has several cal sil pieces laying around which I can join to form one "slab", as well as several 24x24in foamglas pieces.
      Should I make the extra effort and find a supplier to build insulation with as little segments as possible?
        • 9215
        #33
        Segments ar fine. In fact they have the advantage of allowing a pathway for moisture to escape, provided you have some drain holes in the supporting slab. Just don’t make the gaps too big.Maybe nothing bigger than 1/4”. The floor bricks will easily bridge over that.
