Re: 42" Pompeii in S. Louisiana
I made the insulated door Sunday. I thought it would be difficult to bend the inner, upper section that mates to the arch, but it wasn't bad at all. Good thing I saved the form I used when building the brick arch. I tacked the 1/8" thick by 1.5" wide steel to one of the vertical sides. The steel bent fairly easily around the form. A few tack welds held it in place. I filled the cavity with the Thermo Gold board I used under the oven floor. The door seems to work well enough as the temp was 375 degrees tonight about 24 hours after firing. I plan to add gasket material around the lip.
