42" Pompeii in S. Louisiana
  • Kurtloup
    • Jan 2013
    • 147
    #166
    Re: 42" Pompeii in S. Louisiana
    I made the insulated door Sunday. I thought it would be difficult to bend the inner, upper section that mates to the arch, but it wasn't bad at all. Good thing I saved the form I used when building the brick arch. I tacked the 1/8" thick by 1.5" wide steel to one of the vertical sides. The steel bent fairly easily around the form. A few tack welds held it in place. I filled the cavity with the Thermo Gold board I used under the oven floor. The door seems to work well enough as the temp was 375 degrees tonight about 24 hours after firing. I plan to add gasket material around the lip.
    • Kurtloup
      • Jan 2013
      • 147
      #167
      Now that I have the insulated door completed, I'm closer to cooking a pig. Since I can't weld aluminum, I had a sheet metal shop make a drip pan that is 19" x 36". Last weekend, I welded a rack to fit in the pan allowing me to slide it out as one piece. I have expanded stainless steel which fits over the rack to hold the pig.
      • Kurtloup
        • Jan 2013
        • 147
        #168
        I made the chimney cap today out of steel and galvanized screen. It didn't appear to have a negative effect on the draw.
        • Crawfish fest
          • Jul 2013
          • 75
          #169
          I was looking all over the net today for a drip pan to fit my oven to do a pig next weekend. I may get a tray made like this. A standard sheet pan is too wide.
          Have you cooked a pig yet?
          Will you have it butterflied?
          Michael
          • Kurtloup
            • Jan 2013
            • 147
            #170
            B&C Sheetmetal in Denham Springs made the pan. I paid for it on Friday afternoon and it was finished on Monday. I haven't cooked a pig yet. Will do it in a few weeks. I plan to cook it butterflied, but I have no reference for the actual size. The smallest I have found in town is 15-20 lbs.
            • Crawfish fest
              • Jul 2013
              • 75
              #171
              I am going to do a ham for the Furman game.
              Thanks for the source on the metal work
              • Kurtloup
                • Jan 2013
                • 147
                #172
                I made a few more things for next weekend, a rack for grilling oysters and a door that will hopefully allow smoking when I cook a small pig.
                • irelande5
                  • Feb 2012
                  • 133
                  #173
                  like that door, what material did you use?
                  http://www.fornobravo.com/forum/f8/p...s-i-18098.html
                  • Kurtloup
                    • Jan 2013
                    • 147
                    #174
                    Thanks. I used 1/8" aluminum.
                    • Kurtloup
                      • Jan 2013
                      • 147
                      #175
                      Sweet dreams little pig, sweet dreams.
                        That's what I'm talk'n about .
                        • Kurtloup
                          • Jan 2013
                          • 147
                          #177
                          The pig came out good, but I'd change things up next time. The oysters were good too.
                          • Kurtloup
                            • Jan 2013
                            • 147
                            #178
                            Here are two video clips. The first is the oysters cooking then crackling the pig skin.
                            • kbartman
                              • Feb 2013
                              • 572
                              #179
                              Your making me hungry
                              Respectfully,
                              KB
                              My build
                              • Crawfish fest
                                • Jul 2013
                                • 75
                                #180
                                I am thinking of making a rack for the pig
                                maybe something like an inverted V with a drip pan.
                                what would you change on the pig?
                                how much did the pig weigh?
                                thanks
                                m
