42" Pompeii in S. Louisiana
  • Tscarborough
    • Oct 2009
    • 3341
    #91
    Re: 42" Pompeii in S. Louisiana
    Actually, after looking at the other pics, it should be fine.
      Looks great! Kurt,
      I see that you went with the flared entry. That "sceeaared" me a little, so I found a work around to get the same clearances. But, I do love the look and possibly the "challenge" of a flare. I'm Following your build with great interest .
      • Kurtloup
        • Jan 2013
        • 147
        #93
        Thanks. I plan to add buttressing anyway. The clay flue I bought has exterior dimensions of approximately 8" x 12.5". I need to do some research as to how to brick the area between the arches.
        • Kurtloup
          • Jan 2013
          • 147
          #94
          Originally posted by Gulf
          Looks great! Kurt,
          Thanks. It wasn't difficult at all. A poster provided a measured drawing of their vent in an old thread. I copied their work.
          • chirobuggy
            • May 2008
            • 44
            #95
            great looking build. love the shape of the stand too!
            • Kurtloup
              • Jan 2013
              • 147
              #96
              After getting the proper angle for the next row of bricks using the IT, I switched over to an exercise ball. It worked great.
              • boerwarrior
                • Apr 2013
                • 454
                #97
                Very Nice, Kurt! Almost there!
                It's a very exhilarating feeling putting the keystone in the dome! (my wife says I need to get out more)
                Neil
                My Build: http://www.fornobravo.com/forum/f8/3...nia-19283.html
                • Kurtloup
                  • Jan 2013
                  • 147
                  #98
                  Thanks. Can't wait to close in dome. Seems like I have been working on it forever.
                  • fabby
                    • Jan 2013
                    • 111
                    #99
                    You will get there. It looks great. I noticed you have filled in the joints as you go along. Smart. I had to come back and fill the outside joints, and that took longer than I had planned, I even tried a grout bag, which worked OK but I was so tired of mixing small batches of heatstop 50 and ready to work on the next phase of things.
                    • Kurtloup
                      • Jan 2013
                      • 147
                      #100
                      This afternoon, I checked the inside of the last row of bricks and found I have a bit of fill needed in some of the joints. I cleaned the inside joints after I removed the ball after the mortar set for a few hours. I didn't do as good of job as the lower rows. It was easy to fill the joints as I added bricks using the IT. I'm over it now though. You have to really bend over to see the top of the dome through the entry. I'm not going to worry about cosmetics. I doubt I will be able to fit in the oven to clean it out so I wanted to take care of the joints as I added bricks.
                      • Kurtloup
                        • Jan 2013
                        • 147
                        #101
                        Getting closer.
                          Dmn right! Kurt,
                          As we used to say "near about, almost, but not quite plumb finished" Actually, you are getting close to a real milestone. It will be a great feeling to get that keystone set. Keep it up .
                            • 5260
                            #103
                            On the home stretch, seems like it take as long to do a plug as it does to do a course. Enjoy the ride.
                            • Kurtloup
                              • Jan 2013
                              • 147
                              #104
                              Thinking ahead, does anyone know of a source for spark arrestor screen? If I can't find a cap to fit my clay flue, I'll have to make one.
                              • Bec1208
                                • Nov 2012
                                • 416
                                #105
                                Kurtloup, great looking build. Looking forward to seeing pizzas coming out. Bruce
                                Link to my build here:
                                http://www.fornobravo.com/forum/f6/3...lly-19181.html
                                Selected pictures of the build.
                                https://picasaweb.google.com/1168565...g&noredirect=1
                                sigpic “In theory, theory and practice are the same. In practice, they are not.” ― Albert Einstein
