I am getting myself a little confused about the terminology used around the angles. I've attached a quick and dirty diagram showing what I'm talking about. Feel free to tell me the terms I should be using in place of the ones that I have labelled in the picture
If I am building an oven with the minimum of mortar each brick will have four cut faces. I suspect but I don't know for sure! that the majority of the calculations assume that you've "only" cut the two ends.
If this assumption is correct
1) is there a calculator that takes into account what I have termed (probably incorrectly) the taper
2) would I need to adjust the design of the IT to match the taper angle in the cradle bit that supports the brick - this seems logical however I haven't seen anyone do it so it makes me worried that I'm wrong
Miles
Miles
