Re: 39 inch Pompeii in Lincolnshire England
After a look around I came to the conclusion that no matter where I got it from blanket insulation is really expensive. A 7.32 meter length of 610mm by 25mm 128kg comes in at ?60 to ?70
So today i took a trip to a local refractory supplier who sold me some decent offcuts. I know you cannot over insulate but I bought too much... way too much. Well I thought I might as well fill the truck as it was so cheap.
I came home with over 100kgs of 128kg density 25mm. I reckon that's about 8 7 meter rolls worth. For ?50!
If anyone wants a few boxes you are welcome to them. I am just a few miles off the A1 near Grantham.
I also got vermiculite to mix up for the base. Wondering how thick the base would be with 200 liters just casting under where the firebricks will be?
Next job is to make an adjustable jig for the saw.
) sheet under the oven floor as an extra moisture barrier. Not 100% sure the plastic would stand the test of time but cannot see the metal ever reaching the 660C it would take to melt.
