Oven Floor Height
  • K79
    • Nov 2012
    • 391
    Oven Floor Height
    You guys are doing a great job keeping up with my 1 million questions. I just want you all to know I really appreciate the help.
    That being said another question
    What is the distance from the ground to the floor of your oven. Just contemplating putting my oven floor around 48" off the ground? What is a comfortable working height?
    Thanks.
    Link to my oven build on YouTube:
    http://www.youtube.com/watch?v=Ujb7lqVcSzQ
  • Les
    • Sep 2005
    • 2945
    Re: Oven Floor Height
    My floor is 41 inches and I am 5'10. I think I got the numbers from the plans but in reality it would have been better if the floor was probably 46 inches.
    • shuboyje
      • May 2009
      • 406
      I like a bit more hands on method. Hold a peel(or broom since you probably don't have a peel yet) at the top of your chest like you are about to launch a pizza. Hold it there and have somebody measure it's height off the floor. That gives you a good idea of how high your hearth needs to be so you aren't bending over to use the oven or look inside. I bet it's higher then you imagined.
      • Les
        • Sep 2005
        • 2945
        Just a heads up. It's more than working the peel for pizza. You will be lifting 22 pound turkeys, pork shoulders, crock pots, etc... Although it's nice not to bend over for pizza it's also nice not breaking your back for the rest of it. It's always about the compromise...
        • shuboyje
          • May 2009
          • 406
          That comes down to the user and what they are after. I'm pizza centric, it's the only thing that matters to me and too low of a hearth can be miserable.
          • Bacterium
            • Apr 2007
            • 560
            As others I like mine slightly higher. So the rule of thumb I have worked on (for my own oven )is bottom of my elbow (with arm bent).
            Damon
            Build #1
            Build #2 (Current)
